need injector help
Old Jul 14, 2007 | 08:19 PM
mademan6889's Avatar
need injector help
Ok to start i have a 383 stroker.all forged,with an lt4 top end and a dual 58mm tpis throttle body.What size fuel injectors would be the best fit for this car?
Old Jul 15, 2007 | 10:52 AM
Wrong forum.... this topic is routinely covered on the "Fuel and Ignition" forum.
Injector size it determined by flywheel HP. A simple guideline - for minimum injector size on a normally aspirated application, multiply your estimated max flywheel HP by 0.07
Example:
500 flywheel HP x 0.07 = 35 #/HR
That assumes a BSFC of 0.476 and a max injector DC of 85%. A better, more efficient tune will reduce the BSFC, requiring less injector. A lower duty cycle is always a good, idea, and that would require a larger injector.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
