ford racing Red Top Fuel injectors?
Old Jul 12, 2007 | 05:00 PM
Wishmaster's Avatar
I dont know the part number....but will those fit on a GM car? they came off a Im thinking 94 to ???? mustang?
if I get them from a friend of mine will the fit?..he doesnt know the part number though.
they are 30lb injectors which is just what I need cause some of the ones that came on my block are leaking..
thanks
Old Jul 12, 2007 | 05:33 PM
mdenz3's Avatar
They should fit, just check the resistance to see if they are high or low impedence injectors. Also, you will need to reprogram your car to run properly with them.
Old Jul 12, 2007 | 05:40 PM
Wishmaster's Avatar
my current injectors are 30Lbs...or atleast Im thinking they are...but yeah, when I had my computer retuned for my new setup...he did it assuming I had 30lbs.....what do you mean by High or low? will that make a difference?
The guy who had them switched from 30 to 42's ....if that means anything...
Old Jul 12, 2007 | 05:57 PM
mdenz3's Avatar
Your car should have high's in it now, and you'll need to make sure the new ones are the same. (i'm just not sure if those are or not)
Old Jul 12, 2007 | 06:01 PM
dangalla's Avatar
just a note: even if you do have 3o# ers in there now, the svo injectors are rated at ford factory fuel pressure, in a camaro they will act more like 37# injectors due to higher fuel pressure, what im sayin here is your gonna need a tune
Old Jul 12, 2007 | 07:10 PM
Wishmaster's Avatar
will the car still run? so I will be running rich? will that have a bad affect on the car until I get it reprogramed?
what do I want? high or low impendance?
thanks
Old Jul 12, 2007 | 07:23 PM
dangalla's Avatar
where are yours leaking from?
pretty sure you want high impediance
can you get a part num off the red tops, on the side of the injector or something
i strongly advise against putting them in there with out knowing what they are and having it tuned for them, without knowing what they are its hard to predict what is going to happen
Old Jul 12, 2007 | 09:05 PM
Wishmaster's Avatar
this is the numbers on the side.....F1SE-E5A
my injectors are leaking fuel into the head....causing a puddle sitting on top of the closed valve...I talked to Rich ar Cruzin and he said that all he can do is clean them ...he can not repair a leaking injector...says it may be dirt in there causing it to stay open..but no way to tell unless I send them to him...so instead of maybe wasting money on that...I'll just buy some that I know are good..
Old Jul 12, 2007 | 09:59 PM
mdenz3's Avatar
With that part number they should fit in no problem and will be the correct resistance. it may run rich until though.
Old Jul 12, 2007 | 11:02 PM
Wishmaster's Avatar
i'll email the guy who did my tune and ask him if putting in some 30 SVO's will cause a problem with the tune he gave me....I did it mail order and when asked about the injectors...I just put down 30lbs.....didnt specify what kind...so I may be ok...
my tune is from LSRacingchips.com
thanks!!
AdsoYo
May 2, 2018 03:21 AM
Collector Car
Dec 17, 2014 01:12 PM
JSK333
Sep 9, 2002 10:33 PM
