can opti's be repaired after coolant spray?
I just replaced the opti, water pump, timing cover seals gaskets, plug wires and oil pan gasket. Ran bitchen till I got off the freeway, then the low coolant sensor comes on, car's missing, and the SES light active.
I check it out and had a pinhole leak at the heater pipe near water pump bleed screw leaking down on the Opti.
Is there any way to repair the opti? Or do I just replace another one
Thanks,
Chris
Thanks,
Chris
(the blue rubber thing around the plug) on it. In my experience, antifreeze usually leaks down thru the opti harness plug and not around the opti casing.
LJ
IgorT.455/406
Mar 12, 2015 03:39 AM
