Gearing, stall, 26" tire, 100 shot?
Old Jul 7, 2007 | 10:22 AM
Z-RATED94's Avatar
I tried the Nitrous forum, but that didn't pan out to well. So here's the question. I'd like to run a 100 shot next year. Do you guys that use nitrous think I'll have enough rpms to pull this off. In a couple of weeks I'm changing from a 2800 stall to a 3600. Hopefully this will put me in the 11.90s with a little weight reduction. Right now the car is crossing the line at 5600rpm. Peak HP is 6k and the 1-2 shift is at 6400 and the 2-3 shift is 6300. With the 3600 stall I have no idea what the rpm will be when crossing the line. And that leads me to wonder if I can even use a 100 shot for at least 2nd and 3rd gear.
So if any of you have some experience with this, please throw some tips my way. Thanks in advance. Rick
Old Jul 7, 2007 | 10:43 AM
FastLt1's Avatar
I would say 4.10 gears and 3800. I want to be able to footbrake a 3000. So the nitrous hits as soon as I let off the brake. 100 shot should take a second off and give you about 10 mph. I was always told you want to cross the line at almost redline. A good link to figure gear ratio. http://www.f-body.org/gears/ Another good one for et estimates. http://www.fbody.com/calc.htm
Old Jul 7, 2007 | 11:11 AM
Z-RATED94's Avatar
FastLt1, are you saying if I run nitrous, it has no bearing on changing the rpms when I cross the line?
Old Jul 7, 2007 | 11:27 AM
FastLt1's Avatar
No not at all. More hp, quicker et, higher mph, higher mph more rpm. Need to play around with how much an extra 100 hp not rwhp will add to your times and mph now. Then mph and rpm range you want to cross at. Higher stall will help your et more then mph. I'd do the nitrous and stall first and see what she runs. It should be very low 11s maybe even high 10s. I suggest 4.10s because traction might become problem with 26s and may need to switch to 28s.
Old Jul 7, 2007 | 11:31 AM
Z-RATED94's Avatar
So what kind rpms are you turning at the line with your set-up?
Old Jul 8, 2007 | 10:53 AM
tireburnin's Avatar
Add 10mph to your trap as an estimate.
That puts you at 124mph. Go find a gear calculator (I think there is one at the top of the page) and figure out what gearing yields around 130mph capable givin your desired rpm. You have to figure in converter slip which can be 5-10% depending on the converter unless you plan on locking your converter on spray.
Gearing has more to do with crossing the finish line than does a stall. A stall's biggest effect is converter slip. If it slips a lot you need more gear (numericly). If it is relatively effecient than less gear (numericly) is required.
Old Jul 8, 2007 | 05:35 PM
Z-RATED94's Avatar
Thanks guys, I appreciate the replys. Rick
Edit, I just looked up some dyno sheets that have mph. On one they took the car to 125, and on another pull they took it to 130mph. Looks like I might be good to go, if I use a first gear lock-out.
Old Jul 11, 2007 | 04:01 AM
AL SS590 M6's Avatar
According to your first post your trapping 114+ at 5600 rpms that's 50 RPM per MPH. So if a 100 shot gives you 10 MPH then you'll trap around 6100. Should be fine.
Old Jul 11, 2007 | 07:58 AM
Z-RATED94's Avatar
Thanks, now if the stock shortblock doesn't mind, I'll be good to go.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Dec 1, 2016 05:37 PM
Collector Car
Dec 17, 2014 01:12 PM
