AIR pump ??
Old Jun 23, 2007 | 02:50 PM
Wicked 97TA's Avatar
AIR pump ??
I've been hearing a loud whistling sound when my car is running. I was looking at the AIR pump today and the short 90* tube coming off the side of it is just there with nothing on the end of it. Is is supposed to be like that? My car is a '99 and it had a high flow lid on it when I got it.
Old Jun 25, 2007 | 10:43 PM
'02 WS6's Avatar
Mine did the same thing, I had the supplied filter for the hose, which was tucked behind my proportioning valve. But I had pacesetter LT's & TD's installed so no more AIR provisions. I pulled the fuse for a couple of weeks, because it was driving me crazy, and making my volts bounce. Then I just removed it all together, and had the SES codes tuned out for good measure. (Never threw any, but they usually do.)
Old Jun 26, 2007 | 01:36 PM
teke184's Avatar
not sure what elbow you're talking about.
but the air pump should only run for a few minutes after start up.
pull the fuse and see if the sound goes away...if not...it's something else.
alhtough the lid could easily cause a noise...that's part of the fun
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Magenta_Hearts
Mar 22, 2015 03:36 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
