Will this hurt my combo?
Old Jun 14, 2007 | 10:34 PM
mdacton's Avatar
Flows 1250 cfm...this is a 4150 accufab
Even at 100% VE I wouldn't need that much CFM
LT1 with ported 374 GM castings......flowing good, but not finished yet.
No camshaft selected as of yet
comp ratio of 12.5:1
Vic intake.
Any input on this would be a great help.......
some other info DFI,4500 converter, 4.57 gears, 28" tires
Need to keep the revs under 8K......the lower the better, I need this thing to last. It will be my new bracket car
EDIT: found this cheaper cast one...only flows 1000cfm, would this one work better?
Old Jun 18, 2007 | 05:55 PM
mdacton's Avatar
someone give me an opinion...am I asking a dumb question here?
I am fairly new to EFI/tuning
and overcarbing would kill a great combo...
Old Jun 19, 2007 | 09:31 AM
jerminator96's Avatar
I don't think it will matter. The problems with having too big of a carb are not factors with fuel injection. I'm not 100% certain though.
Old Jun 19, 2007 | 09:41 AM
ulakovic22's Avatar
Doesn't matter with fuel injection, you can go as big as you want. With it being a 4bbl you will actually get better throttle response, driveability and tuneability.
What motor, car, etc.? 4th gen with a SBC or LT1? You running the EFI manifold or going to convert a carb manifold?
Old Jun 19, 2007 | 02:57 PM
95ttoplt1's Avatar
I would run it.
I'm going to use one of the 3bbl ones, wih the progressive linkage. SHould make for better tip in and the flow required when spinning and spraying
Old Jun 20, 2007 | 04:25 PM
Rice Killer87's Avatar
I would pick a cam first and call the company up and talk to their tech line,and if they dont have one find another place that makes the same thing and talk to theirs. They will be the best help on getting you the right T/B for you app.
Old Jun 20, 2007 | 05:47 PM
SStrokerAce's Avatar
EFI can almost never be over throttle bodied, the more CFM the better, because you have less vacuum in the plenum at WOT.
Bret
Old Jun 20, 2007 | 06:53 PM
mdacton's Avatar
Bret
o.k. I got the bigger one.
Cam's maro
Aug 11, 2015 07:45 AM
colts0455
Jul 8, 2015 12:21 AM
Flint78
Jun 21, 2015 01:28 PM
May 21, 2015 01:04 PM
canbaufo
Parts Wanted
Feb 21, 2015 11:51 PM
