Looking for a 97 Camaro Gauge Cluster Pinout
I need an instrument cluster pinout diagram just like the one show below found on shoebox's page but I need one for a 97 Camaro. Does anyone have one? I tried searching a few forums and found some links but they were all dead.
remember, this is for a 98, but 97 up should have the same pinout in theory
Pin Wire Color Circuit No. Function
A1 PNK 39 Power feed from gages Fuse 9
A2 DK BLU 1936 Fuel gage signal
A3 GRY 728 SECURITY indicator lamp control
A4 BRN/WHT 419 SERVICE ENGINE SOON indicator lamp control
A5 PNK 39 Power feed from gages Fuse 9
A6 YEL/BLK 68 Low coolant level indicator control
A7 BRN 358 AIR BAG indicator control
A8 PPL/WHT 1572 TCS OFF indicator control (with NW9)
A10 TAN/WHT 33 BRAKE warning indicator lamp control
A11 LT GRN 11 High beam headlights on
A12 PPL/WHT 237 FASTEN SEATBELT indicator lamp control
A13 ORN 640 Power feed from PWR ACCY Fuse 7
A14 RED 225 Generator output indicator control
A15 BRN/WHT 1173 Oil level lamp signal
A16 DK BLU 1537 LOW TRAC indicator lamp control
A17 DK GRN 135 Coolant temperature sensor signal
B1 BRN 9 Odometer illumination
B2 GRY 8 IP illumination lamps feed
B3 BLK 650 Ground
B4 WHT 375 SKIP SHIFT indicator lamp control (V8 only)
B5 DK BLU/WHT 1415 Right turn signal switch output
B12 DK GRN/WHT 817 Vehicle speed signal-4000 pulses per mile
B13 WHT 121 Tachometer signal
B14 LT BLU/WHT 1414 Left turn signal switch output
B15 BLK/WHT 451 Ground
B16 TAN 31 Oil pressure indicator control
B17 LT GRN 867 ABS fail signal
B3 BLK 650 Ground
Re: Looking for a 97 Camaro Gauge Cluster Pinout
B3 BLK 650 Ground
B3 BLK 650 Ground
Free download of 1996 factory service manual, courtesy of GaryDoug:
https://www.mediafire.com/?40mfgeoe4ctti
It has the pinout diagram.
Dose anyone know of a harness that will plug into this other than the instrument cluster itself? I would like to connect a few of these items to an aftermarket dash but would rather not cut up the factory harness.
Cool thanks man. I will try to test some of the wires to see if they match your schematic. Hopefully the 98's are the same because I can't seem to find a 97 diagram anywhere.
