Front "spring" sound when going over small bumps
Old May 21, 2007 | 08:57 AM
Camarocracy's Avatar
I just noticed this yesterday driving on a road I usually don't drive on. The road had small bumps, more like really small patches to make the surface uneven. My front end would make small "bed spring" type sounds when driving over them at around 35mph. Should I get my swaybar bushings greased and my endlinks checked?
Old May 21, 2007 | 11:54 AM
ConElite's Avatar
If you still have stock end links and bushings I recommend getting some Energy suspension Poly Bushings. They are so much better than The stock Hard PLastic ones. AutoZone Carries them for about $20-28 for the bushings and end links.
Old May 21, 2007 | 05:08 PM
I had them replaced with the poly ones last year.
Old May 22, 2007 | 11:37 AM
2000GTP's Avatar
The "squeeking" noises can very well be as a result of dry bushings. Grease them up and see if the problem persists.
Old May 22, 2007 | 09:42 PM
canuck94z28's Avatar
I had the same noise coming from my factory rear sway bar bushing and needed to regrease them 2-3 times a year.This year i put on poly ones on and so far no problems/or squeeks.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jazsun
Dec 29, 2014 12:14 PM
siguy
Nov 27, 2014 10:07 AM
ford
Aug 3, 2002 02:39 PM
