Bent my upper A-Arm, how do I remove bushings?
Old May 18, 2007 | 02:49 PM
rhummer37's Avatar
Question Bent my upper A-Arm, how do I remove bushings?
Situation 1
Situation 2
Zoomed in
I accidentally bent my upper control arm trying to get one of the bushings out. Can I just straigten it out and forget about it or am I going to have structural integrity issues?
More importantly, how can I get these bushings (none yet removed) out since the ball joint remover I have just crushes the a-arm?
Thanks for any replies.
Old May 18, 2007 | 08:05 PM
Z28luvr's Avatar
put a socket (or some other kind of spacer) in there so it does not crush the a-arm. I had the same problem........
Old May 21, 2007 | 01:31 PM
jchrisos's Avatar
I used liquid wrench and let it sit for 15 minutes. I then just pounded on the "can" until it came out. I then heated the "cans" with a torch which then just slid out (much messier than it sounds).
While using the press, would it be possible to wedge something in between the folds of the a-arm so it doesn't bend? A thick screwdriver maybe? Just an idea...
Just so you know, i had a h3ll of a time getting those cans back in. i.e. the lip was not flush with the a-arm like it originally was, but it was in far enough that there was a lot of the "can" coming out the other end of the a-arm. I now have a new "popping" noise, but I think its related to my lower bushings. Please let me know if you are able to get them in all the way and if you have any new noises.
HarleyZ28
Oct 5, 2015 06:23 AM
Fatdog2
Apr 27, 2015 10:32 PM
Apr 16, 2015 09:57 AM
Jason Short
Jan 19, 2015 06:34 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
