a/c will not work until I jump out the relay
Old May 10, 2007 | 05:47 PM
Fbody1's Avatar
Question a/c will not work until I jump out the relay
my a/c has worked fine until a few days ago. It still has pressure(I don't know how much)but when I turn it on the compressor does not come on. but if I jump the a/c relay b1 to b4 it will come on. what is wrong ?
Old May 10, 2007 | 06:09 PM
er-z's Avatar
start by changing that relay
Old May 10, 2007 | 06:19 PM
bingo's Avatar
If that doesn't work, you might try to reset the PCM.
Old May 10, 2007 | 08:34 PM
Fbody1's Avatar
I have swaped out the relay and it still does it ,I will try and reset the pcm.
Old May 10, 2007 | 08:57 PM
Fbody1's Avatar
ok I reset the pcm and it worked.why did it do that? anyway thanks for the help now I don't have to sweat my *** off any more
Old May 10, 2007 | 09:09 PM
godofdragons's Avatar
Just for future reference, I had the same problem once and it turned out to be a clog in the system. I jumped the relay and it burnt out the clutch. Now I have no A/C
Old May 10, 2007 | 09:14 PM
bingo's Avatar
I don't know why. My friend had the same problem and this is how we fixed it.
Old May 11, 2007 | 09:50 AM
OBE1 95Z28's Avatar
The PCM monitors the AC pressure level; if the level is out of range, the PCM won't allow the compressor to kick on.
Red Hawk 94
Mar 18, 2019 04:03 PM
alphaauto
Feb 5, 2015 05:25 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Jeff1904
Jan 3, 2015 12:00 AM
