Getting window up with bad motor, and no engine, harness, or PCM
Old May 10, 2007 | 10:35 AM
30AnvZ28's Avatar
I have had my driver side window down for 2.5 years, while we built the new motor for the car. I took the interior out just for this reason. With the floorboards in bad shape, I want to get a new window motor in the car, and then be able to put the window up... however I have no engine, wireharness, PCM, ect in the car.
Is there a way to run power to the switch or something to get the window to go up and down that way I can change the motor out, and get the window up so I can start redoing the interior?
Old May 10, 2007 | 11:26 AM
shock6906's Avatar
You should just be able to touch a DC battery to the power leads on the motor and get it to go up or down.
Old May 10, 2007 | 11:27 AM
30AnvZ28's Avatar
Thats kind of what I thought... but any ideas on which wires these would be? Would that also send the power that needs to be at the switch to send the signal? I know Ill need to move it up and down to switch out the motor... but then I just want it up for good after that.
Old May 10, 2007 | 12:04 PM
shoebox's Avatar
Use D and E, if you still have the express down module hooked up. If not, you will have to jump it directly on the motor leads.
Old May 10, 2007 | 12:14 PM
30AnvZ28's Avatar
I havent disconnected anything... its just like it is from the factory. Thanks for the information!! I just printed the pages for your replacement also. Great site!
Old May 23, 2007 | 04:58 PM
30AnvZ28's Avatar
Ok... so what actually makes the window GO UP? Since the switch isnt hooked up, how do I make it go up? Didnt seem to work when I jumped those 2 connections... or am I just not doing something right?
Old May 23, 2007 | 05:58 PM
30AnvZ28's Avatar
N/M The battery I was using only had 10.X volts. Im charging it now... that was probably the problem.
Old May 24, 2007 | 12:32 PM
Z28SORR's Avatar
If the window motor is bad, jumping it isn't going to do any good. If it's not bad, why would you want to change it? It will need changing soon enough.
10V should be enough to run the motor, provided you have enough amps.
There are only two leads, there is no + or -. One way is for up the opposite is for down.
Old May 25, 2007 | 05:57 PM
30AnvZ28's Avatar
Its bad, and I need it UP to change it... and its DOWN.
Old May 25, 2007 | 06:00 PM
30AnvZ28's Avatar
That and its been raining in the car for 2.5 years...
HectorM52
Jul 30, 2017 11:46 AM
willismoons
Feb 14, 2015 08:42 PM
Jan 5, 2015 07:14 PM
Jazsun
Dec 29, 2014 12:14 PM
