Question About Wiring NX Bottle Warmer.
Old Nov 25, 2002 | 05:31 PM
JST8A50's Avatar
Question Question About Wiring NX Bottle Warmer.
Just got my NX Bottle warmer and am a little confused about the wiring diagram. It says to run the GREEN wire from the relay to the heating element and the BLACK wire to 12volts. According to the numbers on the relay that would be running the #87 prong 12 volts in(to relay) to the element and the #30 prong 12volts out(from relay) to a constant 12 volts. Did they just get the wires mixed up on the instructions or is it supposed to be wired this way?
Old Nov 27, 2002 | 08:34 AM
stik6shift98's Avatar
id have to check mine out but i think the black one is ground
Old Nov 28, 2002 | 10:30 AM
robss96dcm's Avatar
yes the black wire does go directly to power, just make sure you put a fuse of some sort inline.
calaban
May 18, 2020 06:43 PM
alphaauto
Jan 23, 2015 07:42 AM
bandit383lt4
Dec 21, 2014 09:12 PM
lbrowne
Nov 13, 2011 04:25 PM
Matt-01-SS
Aug 2, 2002 04:05 PM
