backfire problems
Old Apr 23, 2007 | 03:06 PM
RicocheT's Avatar
backfire problems
Im having a backfiring problem through the intake. It only seems to happen when the car is in closed loop. I can run it fine with a o2 sensor unplugged (although its a little sluggish) but when it goes into closed loop and I mash on it or just try to rev it it'll spit back out of the intake. I didn't know if anyone could give me a hand on where to start looking in the tuning file. I'm using tuner cat..
Car specs
94 z28
Le3 heads, le2 cam (23x/23x about .600 lift), 37lb injectors (racetronix).. Anything else you need to know? so far i've changed just the injector size by the calculation I found on here somewhere, and I'm turned somethings off to keep the computer for checking things, but I'm not sure where I should be looking for the backfire problem.
Thanks in adv!
Old Apr 23, 2007 | 10:31 PM
Purplemaroz28's Avatar
exhaust?
Old Apr 23, 2007 | 10:35 PM
RicocheT's Avatar
If you mean what I have, I'm running kooks 1.75 stepped race longtubes, hooked back into the stock catback
jackpawt883
May 21, 2015 12:34 AM
Drtryder
Apr 22, 2015 04:17 PM
Magenta_Hearts
Mar 22, 2015 03:36 PM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
F(ast)-body
Feb 26, 2003 09:05 AM
