Put my Spec 2 in and....
Old Apr 19, 2007 | 06:08 PM
WSUFlyer's Avatar
I installed a Spec Stage 2 clutch and Pro 5.0 shifter in my 95 Z last week...everything works good, no slipping, no noises, and no vibration. I am wondering about the feel of the pedal. I went from a stock replacement clutch to this spec 2, and it seems that the pedal is actually lighter....mostly at the bottom part of the travel. Also it seems that the clutch fulling engages a little higher than my last clutch. Like I said I'm not having ANY problems with slippage....just mostly not much slipping and a higher than I would expect full engage.
Input?
Old Apr 20, 2007 | 01:52 AM
Bayer-Z28's Avatar
I asked a similar Q on LS1tech after my McLeod single install. I guess it's normal.
Mine fully engages twords the top of the pedal throw too, but it's considerably heavier than the stocker.
The LS7 Clutch is WICKED light too, FWIW.
grabbem88
Mar 25, 2015 12:09 PM
Mar 15, 2015 07:01 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Nov 20, 2014 06:03 PM
