OBD1 LT1Edit help/can't make changes
Old Apr 18, 2007 | 05:29 PM
n2oCamaro's Avatar
I am trying to adjust my PE-vs-RPM table but it will not apply the changes (I know I am probably doing something stupid). I select the RPM I want to change and type in the box labeled "% of change" and then hit "apply changes" and it doesn't change the value. I did a fresh flash of the program to make sure I had a editable file but still the same thing. The program is a base tune from PCMforless. As far as I know, Bryan does not lock his stuff. I have made other changes in the file (like injector size) and had no problems. What am I doing wrong.
Old Apr 24, 2007 | 08:41 PM
n2oCamaro's Avatar
Well after messing with it for awhile, I figured out I can make changes in certain increments (usually .3). Like if the current value is 3.1, it will only let me change it to 3.4 or 2.8. Any ideas?
HectorM52
Jul 30, 2017 11:46 AM
nikolt1
Feb 27, 2015 09:10 PM
siguy
Nov 27, 2014 10:07 AM
