Everyone with aftermarket wheels
Old Nov 25, 2002 | 12:40 AM
SpeC's Avatar
Ok im not happy anymore with my 17" rims and am going to buy wider 18". Got a couple of questions.
I was wondering what the best size would be to fill up the fender well.
What width should i go... 9.5?
What tires should i get? (not rims)
Can i see your pics?
Thanks in advance!
-SpeC
Old Nov 25, 2002 | 10:24 AM
Going from a 17" wheel to an 18" wheel isn't going to "fill up the fender well" unless you go to an "oversize tire" - one with a diameter larger than stock.
The stock sizes and popular aftermarket sizes are generally selected to match in outside diameter..... 245/50-16, 275/40-17 and 315/35-17 all have roughly the same 25.65" outside diameter. If you went to 18" wheels, you would logically select a 275/35-18 (25.58") or a 285/35-18 (25.85"). Neither of those sizes would fill the wheel openings much better than the stock tires.
Other choices would be a 275/40-18 (26.66") or a 285/40-18 (26.98"). There is also a Michelin Pilot Sport in 295/35-18 (26.13") and that would require a 10"-10.5" wide rim. Then there are the Viper rear tires.... 335/30-18 (26.68") but those will require 12"-13" wide rims - not easy to fit on a 4th Gen.
Remember, filling up the wheel openings means increasing the diameter of the tire, and of that increase in diameter, only 1/2 of it "fills" the openings.... the other 1/2 raises the ride height of the car. And a larger diameter tire gives you the same effect as going to a numerically lower rear axle ratio. Then you need to correct your speedo.......
Old Nov 25, 2002 | 02:40 PM
SpeC's Avatar
thanks for the info. TTT
Old Nov 25, 2002 | 03:54 PM
FirehawkNS's Avatar
You can check mine out in the sig. I went 18 X 9's , but I had to do a drop on the car to fill in the gaps. It looked like crap with the 18's and factory gap. Sometimes I wish I would have gotten wider in the rear, But I like being able to rotate the tires, and the wider the tire, the better the chances are to hydroplan on wet roads. All in all I would love to have gone 18 X10's.
Old Nov 25, 2002 | 11:15 PM
SpeC's Avatar
nice car! what rims are those? any one else got info? (yes i did i search but my comp is super ***tty so i takes too long.)
-SpeC
Old Nov 26, 2002 | 12:55 PM
snaksknr's Avatar
Does this help? 18x9 up front and 18x10.5 out back .
http://groups.msn.com/SchubringsPics/shoebox.msnw
WildRidez
Feb 23, 2015 07:24 PM
hotrodyou1
Dec 20, 2014 10:05 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
