How much to spray!
Old Nov 25, 2002 | 12:27 AM
cef97ws6's Avatar
Talking How much to spray!
Ok guys need a little technical advice. I was using a 150 dry system on bone stock LT1. Now I have heads/cam LTheaders but still stock rotating assembly. I estimate on motor it is around 415 horse. How much spray can I get away with on stock pistons. I am hoping to still spray at least 100shot. Anybody getting away with this on a similiar setup?
Old Nov 25, 2002 | 01:57 AM
chesee48's Avatar
why not a wet kit? j/w why u went with a dry kit?
Old Nov 25, 2002 | 04:02 PM
35thanniv.SS's Avatar
I hope you have a larger fuel pump, injectors, and the right spark plugs or your going to be in for a big surprise.
Old Nov 26, 2002 | 12:22 AM
cef97ws6's Avatar
Ok I am not new to nitrous but I do not know the safe limit for the stock bottom end of an LT1. I do have the proper fuel system/injectors/plugs/and ignition that should accomodate the engine, nitrous combination. Also I am in the process of converting to a wet system (TNT) I think they are a little safer with the mods I have. So that being said anyone else with a similiar setup using a 100 shot successfully.
Old Nov 26, 2002 | 07:13 AM
Derrick Redd's Avatar
I've used up to a 175 shot without any problems on my stock bottom-end motor. So a 100 shot should be fine.
Old Nov 26, 2002 | 01:41 PM
gb95zconv's Avatar
With the proper fuel setup you will have no problem spraying up to a 150 shot wet. There are some on the board spraying up to a 200 shot on stock bottoms.
Old Nov 27, 2002 | 11:51 PM
cef97ws6's Avatar
Thanks for the Info guys sounds like I should be OK with 100 shot. I am sure I will get greedy and eventually find the limit ayway.
Old Nov 30, 2002 | 07:06 AM
joeSS97's Avatar
Hey cef97ws6,how do you like that cam?I am going to put that in my ride in the spring .You are about the only one I see with it.TIA
Old Nov 30, 2002 | 12:11 PM
TheZ's Avatar
200 shot WHOA are you serious!!!!!!!!!!!!
Old Nov 30, 2002 | 10:49 PM
cef97ws6's Avatar
joeSS97 Well I just recently got the car back together. I honestly have not had a chance to drive the car much. I did the heads the cam and the headers all at once because I broke a piston in the engine so I had it apart and took an opportunity to do all the above mentioned work. I hope to get it to the dyno within the next month and also will have been able to drive it a bit. I can tell you that the car sounds awesome not too choppy of an idle but just enough so you know there is a cam in it. Throttle is super responsive now. Man I am getting excited just talking about it. I will update my signature though when I get it dyno'd. I am hoping for 350-375 rwhp and I really want to bump that 400rwtq number without the juice.
Old Dec 1, 2002 | 03:38 AM
joeSS97's Avatar
Sounds good,let us in on the results!
Jeff1904
Jun 5, 2016 05:00 PM
damnyankee36
Sep 9, 2015 07:06 PM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
30th Anniv Z28
Aug 1, 2015 10:39 AM
RX Speed Works
Jul 24, 2015 02:25 PM
