Boost w/ cam... Q
Old Apr 4, 2007 | 07:23 PM
Bayer-Z28's Avatar
Boost w/ cam... Q
I'm set on the OFI single kit for next year.
http://www.ohioboost.com/p_ls1fbody.html
I am ordering a 225/225 .581 .581 113 cam from speed inc. I'll be piecing the cam stuff together. PRC duals, hardened PR's, Cam, LS2 chain and LS6 Ported pump. I'll have it by the end of next month.
I have done enough research to know that I cannot do H/C w/boost on a stock bottom end. However, I can do just a cam w/ boost on a stock bottom end. (correct me if I'm wrong).. How much boost can I squeeze safely?
I have nothing done, yet, to my engine except LT's, 160 stat, P+P'd TB and an LS6 intake.
Old Apr 4, 2007 | 08:01 PM
jsetzer's Avatar
I've been helping out on a 242/248 600ish lift cam with a powerdyne 6psi kit.
So far its holding together but stock fuel pump can't keep up.
Made 460 letting out real early.
Old Apr 5, 2007 | 08:06 AM
RealQuick's Avatar
Why is this? Do you mean you'll make too much power with heads/cam/FI versus just a cam/FI combo? If you have ported heads, you can make more power at less boost.
Old Apr 6, 2007 | 10:59 AM
Bayer-Z28's Avatar
^ huh.. I haven't heard that angle yet.
From what I remember reading (it's been a while), I can't do 225 heads w/ a cam and boost.. It's a bit much for the bottom end.
Mar 13, 2016 03:37 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
96SilverRam
Sep 7, 2015 10:51 PM
Henson071
Aug 4, 2015 09:32 AM
