View Poll Results: what should i do
replace with pacesetters- will they handle winter?
50.00%
replace with kooks- can barely afford them
50.00%
replace/fix stock- upgrade later
0%
other
0%
Voters: 8. You may not vote on this poll
semi-unique exhaust thread
Old Mar 27, 2007 | 06:21 PM
landstuhltaylor's Avatar
i just bought a trans am that has several exhaust leaks before the catback. the problem is i am not sure what to do to replace them. i would go pacesetter, but i am worried about them rusting out when daily driven through a massachusetts winter. i MIGHT be able to grab kooks, but i would barely be scraping by and would not be able to work on the other small issues for a while. are there any other stainless options that wont scrape? (SLP) or should i just fix/replace the stock system until i can afford kooks? post up your reasoning.
Old Mar 28, 2007 | 12:24 AM
mrmint69's Avatar
Make sure you get them coated. It will make them last a lot longer. Around 400 for a coated set.
Old Mar 28, 2007 | 02:20 PM
of course. i just dont know if they will last long enough.
Old Mar 28, 2007 | 02:39 PM
CamaroRacing12's Avatar
go with the pacesetter...and just make sure u clean them off a lot
Old Mar 29, 2007 | 11:47 AM
2000GTP's Avatar
My Pacesetters started rusting in less then a years time. This is on a car that never sees rain or snow and is seldom driven. If I were to do it over again, I would have spent the extra money and went with Kooks, no question.
Old Apr 10, 2007 | 09:22 PM
sn8ke eatr's Avatar
coated pacesetters. wash em every so often and make sure there is no salt staying on them
Old Apr 10, 2007 | 09:27 PM
95LT1conv's Avatar
if you can afford them now, and your other problems arent too serious, get the Kooks. my pacesetters did the same as 2000gtp's and they havent even been on a year.
Old Apr 12, 2007 | 11:17 PM
turns out it was rubber that had melted on the exhaust and the previous owner thought it was a leak. thanks anyway
timmy39120
May 8, 2015 11:41 AM
BLK1997Z28
May 2, 2015 01:26 PM
95chwagon
Feb 28, 2015 12:02 PM
armedtrigger
Feb 24, 2015 08:30 PM
