Is this pressure normal?
Old Mar 16, 2007 | 02:48 AM
InsearchofgirlwithTA's Avatar
I have a racetronix 255lph in tank pump... after installing I am now running about ~62psi which is making me run rich I believe. I want to know if I need a fuel pressure regulator or if it should be sorted out through tuning or what?
Old Mar 16, 2007 | 07:31 AM
The Engineer's Avatar
Yes, that is too high! You need it regulated down to 46 PSI with the vacuum line removed (during the adjustment). If you stay in the 43 to 46 PSI range, you shouldn't need any reprogramming. Aeromotive makes a nice LT1 regulator.
WD
Old Mar 16, 2007 | 10:17 AM
OBE1 95Z28's Avatar
Always helpful to know what year car and engine you're running. The answer above assumes you're running an LT1. If you've got an LS1, you running a different fuel pressure.
Old Mar 16, 2007 | 01:03 PM
pattracing212's Avatar
do you typically need a new regulator when putting in the 255 walbro. i believe i was told i don't, but i woudl just like some clarification, before i put it in next week.
Old Mar 16, 2007 | 01:45 PM
2000GTP's Avatar
No, a stock regulator will do the trick just fine. OBE1 95Z28 brought up a very good point though, the LS1 and LT1 run on two completely different fuel pressures, which could account for his pressure setting if he indeed does have an LS car.
Old Mar 16, 2007 | 02:26 PM
Yes, I spend so much time in LT1 engine tech I'm not thinking outside the LT1 box. I also work on LTs constantly, however, my tow vehicle has an LS engine.
WD
Nickster 7
May 1, 2015 09:04 PM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
Alex Barnes
Jan 24, 2015 10:21 PM
jayblev95
Dec 1, 2014 06:55 AM
