Replacing front ball joints, what else should I replace while I'm down there?
Old Mar 8, 2007 | 08:58 AM
CobraEatr's Avatar
The car has 140k on it and I've never changed out the struts or anything down there. What other things should I replace while I'm switching out the upper and lower control arm ball joints? Tie rod ends, struts? Also, what will I need to do a full upper and lower (front) ball joint replacement. I've heard it will be hard to press them in and out, but I'm short on cash and I can't afford aftermarket a-arms. Thanks in advance.
Old Mar 8, 2007 | 09:34 AM
OBE1 95Z28's Avatar
I would replace the outer tie rod ends (Moog), upper and lower A arm bushings and shocks. The stock shocks are poor performers. A set of Bilsteins aren't too expensive and will greater improve handling. I went with poly bushings. If you live in cold weather, you'll probably get some noise with them during the dead of winter but here in CA they're quiet. Also inspect your sway bar bushings and end link bushings.
Also give you wheel a tug and check the front wheel bearings.
Old Mar 9, 2007 | 07:52 PM
jasonisdn's Avatar
our style of front hubs are sealed and you can't replace the bearings correct? you have to buy the entire unit and just replace it in the steering knuckle.
Old Mar 9, 2007 | 10:02 PM
OBE1 95Z28's Avatar
You are correct, but the tug test is still checking for play in the bearings.
Old Mar 9, 2007 | 11:12 PM
jasonisdn's Avatar
gotta ya, i saw that point in your post. i was just making sure i was correct in my thought. i was hoping you were going to say "no , you can change the bearings in the front hub". i would have been happy to see that reply
Old Mar 10, 2007 | 01:28 PM
OBE1 95Z28's Avatar
Best price I've seen for a replacement hub assembly is Autozone's webpage (buying it on-line is cheaper than buying it in their store). It's about $112 and free shipping, and utilizes Timken bearings.
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
mritter1965
Feb 9, 2015 07:01 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
sscott
Jan 17, 2015 04:30 PM
Hurin
Dec 13, 2014 07:38 PM
