Q on installing LCA relocation brackets
Old Mar 5, 2007 | 10:18 PM
Heat Seeker WS6's Avatar
I have the BMR LCA relocating brackets and with regards to the holes in them that get the bolts from the lower shocks mounts. With full weight on the rear, do I just remove the shock's nut, slide out the bolt far enough to get the bracket in place and then tap back in, or is the shock under some kind of pressure and will expand out on me? I just dont want any surprises with this.
thanks!
Old Mar 6, 2007 | 08:24 AM
respectirocz's Avatar
the shock will extend when you remove the bolt but it shouldnt take very much effort to compress the shock to reinstall it
Old Mar 6, 2007 | 11:11 AM
2000GTP's Avatar
Exactly, they take minimal effort to compress back up. Just keep the rearend supported when doing the install.
Old Mar 6, 2007 | 02:24 PM
Thanks for the responses. It was very easy to do. Also installed Spohn adj PHR.
HectorM52
Jun 23, 2016 08:42 PM
lbrowne
Nov 13, 2011 04:25 PM
94B&RZ-28
Dec 22, 2008 10:00 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
