convertible coil springs
Old Mar 3, 2007 | 11:52 PM
z2894droptop's Avatar
My car has stock suspension and does not transfer wait at all. It launches like a brick. I need it to transfer weight to the rear. Is there a cheaper solution other than buying aftermarket stuff. I have heard of buying v6 coil springs. Will that work on my car?
Old Mar 4, 2007 | 12:11 AM
A buddy of mine with a 97 SS convertible used my 94 Formula coupe springs. Car's best 60-ft was 1.30 running mid 8's at over 160mph.
Old Mar 4, 2007 | 12:28 AM
Did he use just the rear springs or the fronts also? Thanks. Also, what kind of 60's did he have on the stock stuff? My best is a 1.9 with stock suspension on 26x10.5 ET streets and still spinning like crazy if I dont feather the gas.
Old Mar 4, 2007 | 10:12 AM
He was running Afco double adjustables and Afco drag springs in the front, QA1 adjustables in the rear, with my Formula springs, mostly Spohn suspension upgrades, except for a PA K-member and a Wolfe sway bar, and front suspension travel limiters.
He was having problems getting under 1.40 60-fts when the car was only running mid 9's. We swapped his Eibach Drag Launch springs for my Formula springs, but made a number of other changes to get it into the 1.3x's, including a personal setup by Steve Spohn.
armedtrigger
Feb 24, 2015 08:30 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
joe777107
Dec 1, 2014 09:32 AM
thenewkid
Nov 27, 2014 09:41 AM
