wiper blades?
I use the wiper blades that fit the 88-95 5 series Bmw as they are the same size.I feel your frustration,the shape of the windscreen makes it hard work for the blades to contact all over the windscreen.
I find that if I lift the wiper arms away from the screen when I wash my car,when I put them back down they never work properly and it takes a few days for them to settle back in.
I'm certainly not one to argue with sucess, but keep in mind that those wiper frames have springs in them that will wear out over time, reducing the amount of pressure on the windsheild.
Of course, if just popping refills in works for you, by all means, keep doing it
The factory wipers have been working perfect for me since day one
. When I did need replacements (after driving 2 winters with the car
) I got replacements directly from GM ... they still work great
I've experimented with different brands of wipers in the past (on past vehicles) and after getting my Camaro, I've NEVER had a problem with crappy wipers
. Factory blades it is!!
.I've experimented with different brands of wipers in the past (on past vehicles) and after getting my Camaro, I've NEVER had a problem with crappy wipers
Definitely justa kiddin. Shoebox is fbody
I even got a set from the dealer :mainly cause I had a discount, and can't go wrong with dealer right?: And they still wouldnt clear the retarded reverse arm on LT1's. So I cut a notch in the arm with a dremel. So now the arm rests inside it. It's still just as tough and works great
From: Knoxville, Tennessee/Mooresville, N.C./Phoenix, AZ/Bristol, TN
good reply!
