polishing?????????
Old Nov 22, 2002 | 01:41 AM
stevem's Avatar
polishing?????????
anyone polished the tpi system
Old Nov 22, 2002 | 10:07 AM
MADD68's Avatar
Lightbulb Show cars
I've seen polished and chromed TPI's on show cars. I think it would take a long time to polish it. You'd have to use a Dremel tool with the small polishing bits.
Old Nov 22, 2002 | 12:01 PM
Ucantcme57's Avatar
It alot of work but it looks good. First I would try to see if someone has a polished setup for sale if not go to www.eastwoodcompany.com Item # 13149 then here are some good tech articles.. http://www.gmtips.com/3rd-degree/dox...m/pol-plen.htm
There ya go..
Kevin
Old Nov 23, 2002 | 05:43 AM
Ekotopia's Avatar
Here You can see a polished TPI setup. He made all himselft by hand, and it took a HELL of a good time. But itīs NICE.
http://hem.bredband.net/b123938/images/pdrm0022.jpg
Old Nov 23, 2002 | 10:45 AM
TunedPort 335's Avatar
Hey if you want to check out my Polished TPI, check out my webpage in my sig.
It took me a lot of time and effort, but it was well worth it. It sets the engine bay apart from the stock looking ones. I will never own a TPI car without polishing the intake, I think it looks great.
Old Nov 23, 2002 | 01:22 PM
StealthElephant's Avatar
damn eko that guys engine is CLEAN, nice job on the polishing, both of you guys
Old Nov 23, 2002 | 02:52 PM
LtsRace's Avatar
Post Polishing
I just recently learned how to polish aluminum. Its a very time consuming process, but its not hard and the end results are awesome. You start sanding the aluminum with 220 grit sandpaper, then go to 320, 400, 600, 800, 1200, and end with 2000. Once im done sanding i use a die grinder hooked up to my air compressor to polish it out. Using red rouge, then white, then the red tube of Wenol. Materials will cost you about 50-75 not inluding the grinder.
good luck, Joe
Old Nov 23, 2002 | 04:35 PM
Ekotopia's Avatar
Yeah, itīs looks awesome. Hereīs another shot. He made a cover that he placeīs when he shows the engine. He has also made some camping-tables and clocks, where heīs engraved the eagle. Too bad I havenīt got any pictures of them.
http://hem.bredband.net/b123938/images/pdrm0021.jpg
Old Nov 25, 2002 | 12:10 PM
RobsWS6's Avatar
Maybe try Jet Hot or Paul Berry. Coating would be a lot cheaper.
football4life
Oct 4, 2015 07:48 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Catmaigne
Jul 14, 2015 05:17 PM
Fastbird93
Jul 11, 2015 04:37 PM
