If i bridge my 2 subs, does it split the max RMS between the two?
Old Feb 14, 2007 | 03:16 PM
chamorro's Avatar
ex- 600w RMS mono push out 300 to each sub?
Old Feb 14, 2007 | 03:21 PM
chamorro's Avatar
also, if i bridge the two subs together, does it lower the ohms?
ex- two 4ohm subs bridged turns into 2ohms
Old Feb 14, 2007 | 03:58 PM
94blackz14.2's Avatar
yes and yes
Old Feb 14, 2007 | 07:14 PM
LS1 RULZ's Avatar
You don't bridge subs. Bridging is an amplifier function. Subs get connected in series, parallel or a combination of the two called series/parallel.
Two 4ohm subs in parallel = 2ohms
Two 4ohm subs in series = 8ohms
As long as both subs have the same impedance each will receive the same amount of power. So if the amp delivers 600W then each sub will get 300W. If one sub is 4ohms and the other is 8ohms then the 4ohm sub will get 2/3 of the power and the 8ohm sub would get the other third.
HibachiZ28
Nov 6, 2015 12:53 AM
football4life
Oct 4, 2015 07:48 AM
secbase8
Parts Wanted
Sep 8, 2015 07:11 PM
Latronaxe
Jul 17, 2015 11:55 AM
