pacesetter long tubes and stock y-pipe
Old Feb 13, 2007 | 06:04 PM
lt1 beast's Avatar
Im supposed to recieve my pacesetter lt tommorrow and im wondering if its possible to bolt them up to the stock y pipe if i cut the y pipe back a little. Thanks!
Old Feb 13, 2007 | 06:06 PM
2000GTP's Avatar
Its not even close. You will have to get the Pacesetter off-road y-pipe.
Old Feb 13, 2007 | 06:26 PM
69gto96z's Avatar
Its not possible, you must either run true duals or buy the off road y pipe from pacesetter. Or you could run open headers
Old Feb 13, 2007 | 09:04 PM
94_firechicken's Avatar
or you could get yourself some highflow cats and a universal x-pipe with some dumps = awesome on an LT1
Old Feb 13, 2007 | 09:35 PM
FryedClutch's Avatar
well technically you can make anything work
but in this case you would have to fabricate your own y pipe
if you have the tools and the skillz to do that by all means do
but if you dont you would be paying an exhaust shop well over the 130 it costs for the pacesetter piece
Old Feb 15, 2007 | 12:18 PM
lt1 beast's Avatar
i never considered running open headers, would that make my motor run too lean?
Old Feb 15, 2007 | 12:20 PM
2000GTP's Avatar
Considering how close the 02 sensors are towards the ends of the headers, the incoming rushes of air could give wacky readings to the 02 sensors. I would either put on the correct y-pipe or do a true dual setup.
Old Feb 15, 2007 | 12:23 PM
lt1 beast's Avatar
yes, that thought was in the back of my mind, i want true duals but they are difficult to fabricate so ill probably end up going with a massive single exhaust since the flow numbers are the same and i am considering an sts turbo. Another question i have is will the knock sensor go off becuase of the long tubes?
Old Feb 15, 2007 | 12:25 PM
2000GTP's Avatar
Its a possibility that there may be some "false knock" present because of the addition of a noisier exhaust. The only way of knowing is to put the car on a scanner and get a live readout. If you are getting false knock, try using an LT4 knock module, they only cost around 30 bucks.
Old Feb 15, 2007 | 12:28 PM
lt1 beast's Avatar
whats the difference between the lt4 knock sensor and the lt1 sensor
Old Feb 15, 2007 | 12:34 PM
2000GTP's Avatar
Heres an informative link: http://www.projecttransam.com/projects1.asp
HectorM52
Jul 30, 2017 11:46 AM
LT14LIFE
Feb 9, 2015 09:35 PM
Cam's maro
Jan 30, 2015 09:21 PM
Jan 5, 2015 07:14 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
