Who said you can't put Daul cats on with LT's
Old Feb 12, 2007 | 07:35 PM
ZL1modified's Avatar
I have pacesetter lt's and this is a pacesetter y-pipe that I
fabricated... (second time welding)
i used 2 magnaflow high flow tc's and you can see where it feeds into my 4" mufflex exhaust system...
I have one question for the experts...
will my lines be ok?
FYI: The lines are no closer than 1/2" from the cats...
And the cats do have a built in heat shield...
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
I put this here because this section is viewed more and this is LT1 specific...
Old Feb 12, 2007 | 07:37 PM
squints88's Avatar
nice. nodnarb481 on here has that setup but with mini cats. fits good
Old Feb 12, 2007 | 07:41 PM
SS RRR's Avatar
I don't think anyone has said you can't. I had one fabbed 6 years ago. My concern is it looks like the drivers side is uncomfortably close to the fuel lines. Good work nonetheless.
Old Feb 12, 2007 | 08:21 PM
Critter's Avatar
nice
Old Feb 12, 2007 | 08:25 PM
2000GTP's Avatar
Nice work. Its not an easy thing to do, but definitely possible. I had a pair of mini-cats welded into my Pacesetter ORY pipe.
Old Feb 12, 2007 | 09:20 PM
2tight's Avatar
Nice job, weld's look good.
Old Feb 12, 2007 | 09:21 PM
nodnarb481's Avatar
it is very uncomfortably close.. unlesssss you move them like i did. Ill try to find some pics of mine
Old Feb 12, 2007 | 09:26 PM
nodnarb481's Avatar
I would move your lines.. its not hard but it is very tedius work (dont mind the spelling or the fact that I probably used that word wrong) I did it by hand but you can buy pipe benders (much better idea) Its a simple solution to what could become a huge problem
Old Feb 12, 2007 | 10:33 PM
shoebox's Avatar
Would I want a 600+° cat that near my fuel lines?
Old Feb 12, 2007 | 11:01 PM
Critter's Avatar
good point ^^^
Old Feb 13, 2007 | 06:02 AM
what about the brake line? will it vapor lock?
k1996z28
Jan 21, 2015 07:22 AM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
Dec 1, 2014 08:08 AM
