Catalytic Converter Placement
Old Feb 12, 2007 | 12:57 PM
1LESSZ28's Avatar
Would putting a catalytic converter in the i-pipe (end of y-pipe) cut down exhaust smell?
I don't have emissions checks but I want to cut down the smell of the exhaust. My headers have emissions hooked up (A.I.R. and EGR). Would the cat get hot enough that far back to do any good? thanks in advance
Old Feb 12, 2007 | 02:45 PM
2000GTP's Avatar
With the cat that far back, it most likely won't get warm enough to be fully efficient emissions wise. If you are only after cutting back the smell of the exhaust, it should help in that regard.
Old Feb 12, 2007 | 02:50 PM
Greed4Speed's Avatar
It needs to be as close to the collectors as possible.
Old Feb 12, 2007 | 05:27 PM
RE AND CHERYL's Avatar
You could put the converters in the trunk, it won't change the smell of the exhaust. To make them work correctly though, they need to be as close to the engine as possible.
Re'
95craz28
11
Sep 12, 2015 07:47 AM
USN06
Sep 7, 2015 03:30 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
Slayer
Aug 17, 2015 03:55 PM
Aug 5, 2015 08:35 AM
