cts or tps help
Old Feb 9, 2007 | 12:48 AM
z28camaro095's Avatar
cts or tps help
can the cts cause the car to run rich, cause it to not want to start and once u get it started shake and run like **** and can it make it once u shut it off not want to restart i own a 91 z28 tpi 335 stroker motor and i have changed the o2 senser and the map senser. help me plz in this troubling time.
note that i just bought a week ago and i did not do the work to the motor still learning about it.
does cts stand for coolant temp senser
does tps stand for throttle posistening switch (senser)
Old Feb 9, 2007 | 06:56 AM
nikkev's Avatar
That sounds like your TPS (throttle position sensor). It is the sensor on your throttle body that tells the computer what position the blade is in. You can unplug the sensor and if the symptoms go away, that is your problem. The car can be driven without the TPS but it will idle really high and drive like crap, but it will run. Good luck.
Old Feb 9, 2007 | 04:52 PM
1987IROC350's Avatar
Same guy different post. Sneaky. Hey are you getting a check engine light? If you are you can use a paperclip to read the code. Anyone can tell ya how to do it. I'll put a link so you can see how: http://www.thirdgen.org/techboard/tp...tml#post989604
Old Feb 9, 2007 | 08:38 PM
i did that it flashed 12 and they said that, that means it ok onthe eletronics so me and my dad r doing to check the fuel regulater and replace it and hope for the best.
Old Feb 9, 2007 | 10:12 PM
Well it flashes code 12 three times, then gives you a trouble code after that. Now if it flashes code 12 another three then you dont have a trouble code. Just in case you didn't get that far. Good luck. I hate hearing new purchases having problems. Dont hesitate to call and ask the guy you bought it from to see what he thinks it might. be.
Old Feb 10, 2007 | 06:21 AM
i called him he doesn't know what could be wrong. ur right i let the code flash 3 times then shut it off i will check that again then thx for the tip so it fllashes 3 times then does the trouble code? thx for the help.
Old Feb 10, 2007 | 06:39 AM
Correct. And it also flashes 12 in between codes if you have more than one code in the computer.
Old Feb 10, 2007 | 10:51 AM
ok well i let it flash 10 times to be safe and it always flashed 12 so in the clear on eletronocs so i am going to look into the fuel regulator an if thats not my problem they sya to change the fuel pump and fuel filter fun fun what do u think.
Old Feb 10, 2007 | 12:41 PM
irocbsa's Avatar
Punctuation? These posts are making my head hurt.
If its not throwing any codes you really need to get a scan tool on it to see why the injectors are dumping fuel. Otherwise, you're just guessing.
Old Feb 10, 2007 | 06:14 PM
Wacky Tower's Avatar
Like I said in your other post you need to get your hands on a scanner. A bad cts will most likely not throw a code I am not to sure about the TPS.
Old Feb 10, 2007 | 09:55 PM
well i chnaged the cts, map sensor, and the 02 senser we found out that the coil was bad and the plugs were firing off to the side so i got the coil changed and i am working on getting the plugs change which is a big *** bitch and the headers r getting in the way lol but 2 of me and my dads racing friends said that that could be the problam seeing how the spark isn't strong so it is probably only burning a % of the fuel while the rest will run out the exhaust so that is were i am at and since there is no check engine light autozone told me that a scaner would not read anythang. well wish me luck and if thats the problem then i will let u guys know thx for the info.
Old Feb 11, 2007 | 09:32 AM
Autozone must have a code reader not a scanner. I have a auto xray scanner that shows what the ecm is seeing in real time and it also tells you trouble codes. You may have found the problem with the plugs and coil. I suggest in investing in a scanner it will help you in the long run so when something happens you wont have to keeps throwing parts at it.
truecontr3
Oct 11, 2015 09:30 AM
drt
Sep 27, 2015 04:39 PM
greenzee28
Sep 25, 2015 04:29 PM
tdigger9899
Sep 7, 2015 10:56 AM
4586
Aug 18, 2015 07:08 AM
