swap items needed
Old Jan 29, 2007 | 11:36 PM
custom95's Avatar
swap items needed
I'm looking for 94 or 95 z engine wiring harness, crossmember, motor mounts, dual cooling fans, a good used radiator, fuel rails, drive shaft, gauge cluster, auto trans crossmember and mounts, accessory brackets, power steering resevoir, headers, aftermarket single cat exhaust and y pipe, and other assorted items. if you think you have anything i can use let me know. The swap is a 94 vette lt1 and vette 4l60e going into a 95 3.4l camaro.
thanks!
edit: I now have almost all of this stuff except for all heater and coolant hoses(only interested if they are in exceptional shape), oil pressure sensor (back top of the block), newer posi unit (I've got 3:23 gears), new or newer 3000 stall converter (preferably yank, vig, or fuddle), and new or newer shocks. I did this edit so you don't have to read through all of the posts.
thanks again
Old Jan 30, 2007 | 01:01 AM
FlashLCD33's Avatar
Im parting out a complete 97 trans am, all parts are 90k miles and the car was BABIED. Poor friend got t-boned.
The only thing I dont have is the exhaust. I can get some painted mid length headers with barely any miles, painted ORY, and a SLP loudmouth catback from a friend if you're interested though.
Best way to reach me is on AIM, JKFBody or JeffZ33
Old Jan 30, 2007 | 03:03 PM
CamaroGuy22's Avatar
Where are you located? I have a driveshaft and a few other parts.
Old Jan 30, 2007 | 07:15 PM
custom95's Avatar
thanks guys, found some items but still need 94 or 95 gauge cluster, power steering resevoir, accessory brackets and engine harness.
Old Jan 31, 2007 | 11:35 PM
Red95T/A's Avatar
guage cluster
I have a cluster out of 95 camaro that i am stripping. I have other interior parts if you need anything. Make offer + shipping.
Lonnie
Old Feb 1, 2007 | 02:13 PM
custom95's Avatar
found a harness
Old Feb 15, 2007 | 11:51 PM
custom95's Avatar
still need low mileage water pump, power steering pump, k-member, heater hoses, ac hoses, coolant hoses, lt leaders and y-pipe, catback exhaust (single cat), fuel rails ( if they are complete with all related lines, fuel pressure regulator, etc.) basically rails and everything located on the intake manifold, engine bay fuel lines. that's all I can think of now.
side note: I'm using a vette lt1- will camaro rail work with this set up?
Old Feb 15, 2007 | 11:57 PM
seawolf06's Avatar
Camaro and Corvette LT1 were almost identical except for the 4-bolt main. I have some shorty headers and y-pipe for sale cheap.
Old Feb 16, 2007 | 08:39 AM
BA383TA's Avatar
I have the fuel rails. They are complete and polished. $65 plus shipping or $100 plus shipping including injectors. Bill
Old Feb 16, 2007 | 08:42 AM
BA383TA's Avatar
I also have the engine bay fuel lines and the p/s reservoir if you still need them. Bill
Old Feb 16, 2007 | 01:21 PM
custom95's Avatar
thanks for the reply, have gotten a few hits on the rails and fuel lines. I already got the resevoir, but if the other set of rails falls through I'll let you know.
Old Feb 16, 2007 | 01:24 PM
custom95's Avatar
what year are they for? what manufacturer, and what kind of shape are they in (have they been modified or anything) coated or painted? Pics would be good.
thanks
Old Feb 16, 2007 | 01:28 PM
mdacton's Avatar
where you located, I have a k-member and some other misc. stuff if you need it
Old Feb 16, 2007 | 02:22 PM
seawolf06's Avatar
thanks
Check them out here.
http://web.camaross.com/forums/showthread.php?t=499924
Old Feb 16, 2007 | 11:14 PM
custom95's Avatar
thanks mdacton, one of the members is giving me a k-member and all I have to do is pay for shipping. if it doesn't happen I'll let you know.
thank you also seawolf06, I checked them out and although they are a great price, but they're not exactly what I'm looking for.
