measuring push rod length
Old Nov 19, 2002 | 08:15 PM
tonyss1's Avatar
Anyone know the procedure to mearsure for push rod length if your going from a standard roller rocker
to a shaft mounted set.
Old Nov 19, 2002 | 09:23 PM
Mindgame's Avatar
Most of the shaft systems come with a setup kit... have only used Jesel and Crower so I don't know about the others.
Anyways, you need to shim the rocker stands til the setup 'rocker' sits at the crest of the 'setup bar'. Then you shim til the top of the valve stem is even with the gap in the setup rocker... just use a straight-edge.
From there you assemble and decide on the proper pushrod length.
-Mindgame
Old Nov 19, 2002 | 10:00 PM
96ltz's Avatar
http://www.compcams.com/information/Products/Pushrods/
Old Nov 19, 2002 | 10:19 PM
tonyss1's Avatar
Measuring push rod length
96ltz........Excellent Thanks
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
Catmaigne
Jul 14, 2015 05:17 PM
mrwz28
Jul 8, 2015 09:11 PM
