Lt1 vs LS1 alignment spec question
Old Jan 10, 2007 | 03:32 AM
Style's Avatar
After I did my LS1 brake conversion and got it aligned, the caster is out of spec left and right (pos). Are the caster specifications different on an LS1 vs an LT1?
Old Jan 10, 2007 | 02:34 PM
multicar's Avatar
I thought the LT1 and LS1s had the same spec, except for the early 4th gen f-bods that had less caster(3.5 instead of 5). Mine set at +4caster both sides, -0.5camber both sides and 1/32toe-in. The spec calls for +5caster but the steering wheel is easier to turn with 4 and I can't feel any difference in direction stability.
What did your specs show?
Doug
oldschool
Feb 9, 2016 09:21 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Hurin
Dec 13, 2014 07:38 PM
ChrisFrez
Nov 23, 2014 10:33 AM
