Low trac and the brakes
I was coming to a stop and my low trac light came on and my breaks went to the floor. Some times if its just setting and ideling the light flickers and the engine tries to die. can any body help
I would also check the ground and positive blocks on the passenger side by the battery. The terminals can really get rusted and corroded and cause some electrical gremlins. You also meant the brake pedal went to the floor? Did it regain pressure immediately afterwards, did you pump the pedal a few times, does the problem only show up when the dash indicators come on?
Topic needs to be in the correct forum..... moving.
I also had this problem i cleaned all the abs connections and rear sensor but it still had the problem i then put dielectric silicone on all the connection and havn't had the problem for 2-3 years.
May 1, 2015 01:14 PM
