Are all lower control arm relocation brackets the same?
Old Jan 5, 2007 | 10:49 PM
KillerTA's Avatar
Are they all the same quality, fit, and finish? They vary in price and I don't see why. Rather expensive too.
Old Jan 5, 2007 | 11:21 PM
hotpart's Avatar
Former Vendor
All relocation brackets are not the same. Some are formed from one piece where some are welded together. Some use 10 gauge materials and some use 7 gauge material. Ours for example are cnc laser cut out of 7 gauge (3/16") cold rolled material and the main saddle is cnc formed from one piece not welded form 3 pieces like others. The other thing to look out for is the mounting holes. I have noticed some make the mounting hole larger and supply a smaller 3/8" bolt. This will weaken the mounting and potentially allow for the bolt on styles to move on you. You can find ours at www.hotpart.com which do not have the downfalls found in other companies brackets. Good luck on your decision and we are always willing to answer questions if you have any.
Old Jan 9, 2007 | 08:43 AM
nb 96 z's Avatar
Some are finished and some aren't, so you'd have to paint them so they don't rust. Also, I'd would suggest welding them. Some you can bolt in, but it won't be as strong or as safe, imo.
Old Jan 13, 2007 | 07:52 PM
metallicsniper's Avatar
Umi's brackets are pretty thick, stong and easy to install, i have bolt ins, which are great and you can weld them if you choose
Old Aug 18, 2007 | 09:17 PM
NOSCaMaRo's Avatar
Same here, I have the UMI design that is 3 piece welded together. Good welds, a weld will be just as strong as the material if done correctly.
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
thenewkid
Apr 12, 2015 07:42 PM
sseeya
Apr 9, 2015 06:38 AM
thenewkid
Nov 27, 2014 09:41 AM
