What is this plastic half round thing?
Old Jan 1, 2007 | 07:26 PM
wrd1972's Avatar
Under the front unibody on the passenger sider there is a half round plastic thing with a single vacuum line attached to it. The vacuum line seems to run along the bi wiring harness on the right side front fender and disappear near the PCM.
What is this half round thing, you can only really see from the bottom when the A-shaped louvered cover is removed.
Old Jan 1, 2007 | 07:32 PM
GMRL's Avatar
You mean this thing?
Old Jan 1, 2007 | 07:33 PM
wrd1972's Avatar
Yup, what is that thing for?
Old Jan 1, 2007 | 07:43 PM
GMRL's Avatar
Its a vacuum reservoir for your HVAC. All that runs off of vacuum, you can hear it working when you turn the HVAC ***** if you listen carefully, sounds like a hissing sound. Opens and closes doors with actuators.
Old Jan 1, 2007 | 07:45 PM
wrd1972's Avatar
So why is it way up there, to reduce noise.
Old Jan 1, 2007 | 07:52 PM
GMRL's Avatar
More than likely that was the only place they could find to put it, not much space to put things in these cars. As youve prolly noticed, things are in some odd places.
rjc1629
Jan 27, 2015 10:46 AM
edman
Jan 25, 2015 02:41 PM
siguy
Nov 27, 2014 10:07 AM
Hal Fisher
Sep 14, 2002 09:36 PM
