Front mount intercooler on LT1 Z28-dimensions?
Old Dec 28, 2006 | 03:44 PM
DirtyDaveW's Avatar
I have found an intercooler with the following dimensions...
Dimensions - 23" wide (31" with endtanks), 11.75" tall, 3" thick
Have any of you installed an intercooler of this size in a LT1 equipped '93 thru '97 Z28 without hacking up (or minimal hacking up) of the nose area of the car?
THanks!
David K. Wilson
'94 Z28 383 LT1 A4 3.42
'96 Z28 383 LT1 M6 4.10 (T76 Turbo being installed)
__________________
Old Dec 28, 2006 | 04:59 PM
Schurters LT1's Avatar
FMIC here
Old Dec 28, 2006 | 06:56 PM
DirtyDaveW's Avatar
I had a reply from another forum member stating that he had to notch some of the bumper support and it worked fine.
I don't suppose any of you have any pictures of the cutting..?
Thanks!
Originally Posted by mgray
What exactly do you mean hacking to the nose area? There are several options here: bumper cover, bumper itself, poly bumper, the light bar, lower bumper cover and radiator support. When I installed mine (same dimensions as yours, but four inches thick), I cut out the lower bumper cover support. I suspect you might be able to fit the intercooler without doing this, but it would be a PITA in general. With a three inch intercooler, you shouldn't have to remove the steel bumper (but indeed the plastic behind the cover).
Old Dec 28, 2006 | 07:07 PM
i haVW PICS OF MY BUMPER CUT.....in sig
Old Dec 28, 2006 | 07:34 PM
DirtyDaveW's Avatar
The video works but the other link gets this response..
We're sorry!
The Webshots page you have requested has either moved or no longer exists.
Click here to visit the www.webshots.com
If you are looking for the Webshots Desktop Software, visit the download page.
Old Dec 29, 2006 | 10:21 AM
RealQuick's Avatar
Dave, here is an unfinished pic, but you can see how much bumper support needs to be removed to get the intercooler to fit in. Its an easy job:
Old Dec 29, 2006 | 10:41 AM
DirtyDaveW's Avatar
Thanks Roadie! That helps a lot!
Dave
Old Dec 29, 2006 | 10:44 AM
RealQuick's Avatar
Dave
Thats my personal car
Old Dec 29, 2006 | 01:22 PM
97WS6Pilot's Avatar
There are pics on page 2 of my cardomain site. I left the main support in place and just cut a hole in it for airflow. I used two L brackets to hang it off the front bumper. Tight fit on a Trans Am.
Old Dec 29, 2006 | 01:43 PM
DirtyDaveW's Avatar
#1. That thing (I.C.) looks HUGE on your car. Is it the same size as the one I specified?
#2. What is this?
http://www.cardomain.com/member_page...30_27_full.jpg
#3. Where did you get the piping for the cold side and what is it made of? Mild Steel? Aluminum? Unobtaineum?
THanks guys!
Old Dec 29, 2006 | 04:51 PM
97WS6Pilot's Avatar
#2. What is this?
THanks guys!
1. It is a 4x31x12 with 3" inlet and outlet. Same size as most on here.
2. That is a Silencer for the mondo valve so its not so loud
3. Universal 3" Piping Kit on Ebay. Aluminum. You'll need 2 or 3 additional 90's.
Old Dec 29, 2006 | 10:19 PM
blown383's Avatar
FMIC pics
Here is my set up.
-B
Old Dec 30, 2006 | 03:38 AM
-vellu's Avatar
Nice pics blown383
How did you route that pass side pipe under the car?
Old Dec 30, 2006 | 01:25 PM
will62085's Avatar
mine has plenty of room, but i just removed the whole bumper assembly all together.
Old Dec 30, 2006 | 01:49 PM
DirtyDaveW's Avatar
Thanks for the pics. That visual helps a lot. Where did you source those pipes and couplers?
Thanks
Originally Posted by blown383
Here is my set up.
