How many psi?
Old Dec 26, 2006 | 04:57 PM
mrmint69's Avatar
How many psi?
My supercharger in working great and i get 5 psi at max boost. The unit calls it a 6.5 psi kit. Is there anything i need to do to make the extra 1.5 or is this typical? I also see they make a smaller pulley for more boost. How much can a stock 100k motor take?
Old Dec 26, 2006 | 05:14 PM
30thTA0525's Avatar
probably wouldnt run too much more without fear of damage.. i ran a very small pully on my powerdyne it boosted well on a stock motor and maxed out around 8-9.5 psi as long as the belt didnt slip and i made sure it didnt get that high unless i had race gas in it... but it made it about 10k miles and had 190k miles on it...about 1/3rd of that time was as low boost
Old Dec 26, 2006 | 05:41 PM
Julio's Avatar
Boost is a restriction. The less the restriction the less the boost. If your engine breathes better than the test engine, then you will make less boost given the same pulley. Just like if you had a clogged cat.. you would make 10+ PSI.
I wouldnt worry about it.. as long as its making power.. who cares. The harder you spin the blower, the tougher it is on parts.
Old Dec 26, 2006 | 06:04 PM
engineermike's Avatar
Rev that thing out to about 6300 and you'll see 6.5 psi.
Old Dec 26, 2006 | 07:03 PM
mrmint69's Avatar
My hypertech can raise the shift rpm's for my automatic. Will this be a good thing to do so the boost will be there higher for longer or just put more stress on the motor? I would hate to do something that could blow it up without being sure.
Old Dec 26, 2006 | 07:06 PM
A centrifugal supercharger will generally shift the rpm range up, by as much as 500 rpm. With that requires higher shift points to fully take advantage of the power. However, with more rpm and more boost, comes a higher chance of blowing it up - especially if you're on the stock pistons.
Mike
Old Jan 5, 2007 | 05:46 PM
CALL911's Avatar
According to my pully size, I should be making 20#'s of boost, whereas I am only making 15 (10 with the air filter on)
Your pulley will make what it makes. The #'s per pulley I am sure is meant as a WAG.
Old Jan 6, 2007 | 07:11 AM
pavement pounder's Avatar
If you see a difference in boost # with or without airfilter, then the filter is TO small !
Old Jan 6, 2007 | 03:44 PM
CALL911's Avatar
I have since upgraded to a much larger air filter. Heck, the old one had already started caving in!
KYWes
Jun 14, 2022 06:52 AM
13qtr
Oct 28, 2016 08:11 PM
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
canuck94z28
Aug 19, 2015 05:50 PM
