How much boost will this combo make? Horsepower?
Old Dec 20, 2006 | 09:50 AM
RRR's Avatar
RRR
Planning on running a p600b w/ fmic with a 15# pulley and maybe a 23% underdrive pulley. Planning on running a much bigger k&n filter as well.
How much boost can I expect from this setup and horsepower/torque?
anyone with a similar setup to compare dyno numbers or people that ran/run the 15# pulley how much boost shows on the guage-mods?
My car has the black bowtie in the bumper cut out so the fmic is visable.
How much boost will the 23% underdrive pulley add? the filter?
Engine will consist of: (93 octane with toulene added CAM tuning later)
50# injectors
dual intank walbro 255s
studded 2 bolt main
forged crank
forged rods
forged dished pistons
arp bolts
stock heads
stock cam
1.6 roller rockers
long tubes (might run mac mids for a while though)
4l60e with a s10 converter and oil cooler
stock 10 bolt
Old Dec 20, 2006 | 10:28 AM
Ponyhntr's Avatar
50# injectors
studded 2 bolt main
forged crank
forged rods
arp bolts
stock heads
stock cam
1.6 roller rockers
stock 10 bolt
Well, if it's a 15# pulley, I would think it makes 15 psi. ATI doesn't rate their pulley's in #'s, just for that reason. A 2.55" 12 rib pulley may make 15 psi on a stock engine with a P600B, but not on a 383. On an engine like yours I would expect between 10 and 12 psi.
Also, a underdrive pulley on a LT1 F-body will not effect boost, because the blower is driven by it's own crank pulley. An underdrive pulley on a car like a LT1 Corvette will actually make LESS boost, as it would slow the blower down.
I would imagine that you should expect about 500-525 to the wheels, but that's just a guess.
Old Dec 20, 2006 | 10:36 AM
CALL911's Avatar
I've never seen a P600 make anything more than 11#'s of boost, so guessing that you make that, my estimate on your RWHP will be around 465 or so with your setup.
If you would change up the heads and cam, I would guess maybe another 75+ extra RWHP though.
Old Dec 20, 2006 | 03:39 PM
RRR's Avatar
RRR
Yeah, it seems that no one makes 15# with what is referred to as the 15# pulley. I heard one guy mad 12# but I think he said boost decreased when he did heads and exhaust so I don't know if he was making 14-15# before that. Anyone else care to comment on the 15# pulley?
Old Dec 20, 2006 | 03:56 PM
Ponyhntr's Avatar
What more are you looking for?
Old Dec 21, 2006 | 02:14 AM
JWS6's Avatar
Mods in sig, stock ATI inlet collapsing, the car saw 10.5# boost, 498RWHP. This was wit the 2.55" pulley(15#'s)
Old Dec 21, 2006 | 08:00 AM
rskrause's Avatar
A quick way to estimate max boost. Courtesy of yours truly.
http://www.kennedysdynotune.com/Blower%20CFM.htm
You can use the formula with a compressor map to estimate boost at less than max impeller rpm.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
ChrisFrez
Mar 1, 2015 01:33 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
