Hey Novaman
Old Nov 18, 2002 | 04:19 PM
dreamer1q's Avatar
Hey Novaman
Sorry I didnt return your call, I was slammed at work today. I hardly had time to call customers back. I dont know too much about the old styles like that. I know I wont have many if any parts for them. I would think you would know more then me. Being that age, the driveline is more like your nova then any car I deal with. If you need anytype of specific help, like interchangability, or finding a hard to find part, let me know.
Q
Old Nov 18, 2002 | 07:19 PM
TheNovaMan's Avatar
Just wondered if there were any common problems I should look out for, besides rust and exploding sidesaddle gas tanks. Thanks just the same.
Anybody else know of any common problems with late 70s/early 80s Chevy and GMC trucks?
Old Nov 18, 2002 | 10:15 PM
Dave89IROC's Avatar
If it's 4X4 or has large tires, it is common for the frame to flex and eventually crack at the steering gear mounting location, it can be welded and reinforced if broken, only prob/issue I can remenber right now
Old Nov 19, 2002 | 12:01 AM
TheNovaMan's Avatar
Thanks. I never would have thought to check that! Why is it that when I'm following one driving down the road, sometimes the bed looks "tweaked"? You know, the front is level from side to side but the tailgate is not--like one corner is bent upward?
Old Nov 19, 2002 | 07:10 PM
Dave89IROC's Avatar
I have an 89 that is like that, I assume most happened the same way, one of the rear spring shackles rusts & breaks and the bed is twisted when is hits(maybe from extened periods driving with the spring against the bed), this is common to most pickups, in fact my dads 94 F-150 needed both(they tore, I found them before they broke completely) the local ford dealer had them in stock! , $25 each!(interestingly enough, this dealer also had fuel tank straps for my old 1977 Lincoln Mark V back in 97)
Old Nov 19, 2002 | 09:27 PM
TheNovaMan's Avatar
So does the bed straighten once the spring problem is fixed, or is it just tweaked forever?
Old Nov 20, 2002 | 07:37 PM
Dave89IROC's Avatar
tweaked forever, all the ones I've seen, it may be ok if it is fixed right away though, without driving on it long/if at all
Javi Fierros
Exhaust System
10
Apr 20, 2017 12:46 PM
alex5366
Jun 14, 2015 10:31 PM
Alex Trujillo
Classic Engine Tech
Jun 9, 2015 08:00 PM
jocamino
Jun 4, 2015 09:33 AM
G-BODYT56
Parts Wanted
May 31, 2015 12:09 PM
