A1000 pump mounting spots?
Old Dec 2, 2006 | 09:26 AM
lethal93ta's Avatar
where did you guys mount your A1000 PUMP, I have a 1/2 inch fitting in the bottom of my tank running 12an line out of that to a filter 12an out of that, but I dont know where to mount that monster pump at the thing is huge, I didnt know if its better to keep it as close to the tank as I can under the stock plug for the tank? or if I should mount it up out of the way further where the old fuel filter was, I didnt know if this pump will suck at all or if it just uses gravity to feed it, the spot where the filter was looks like it would work better but then my feed line to it will be laying straight not down hill to feed it. anyone have any info for me, or pics of how you mounted yours?
Old Dec 3, 2006 | 06:01 PM
mdacton's Avatar
you have a cell or the stock tank?
Old Dec 3, 2006 | 06:43 PM
lethal93ta's Avatar
stock tank.
Old Dec 3, 2006 | 09:30 PM
mdacton's Avatar
i see some probs with that pic.
is that line zip tied to the spring?
pick up shoud probly be in the right rear
i would get some insulated clamps and tie that line up and over the axle.
i think its easier to adapt it to hard tubing and then route it to the front, lighter and cheaper -12an is a little big i think
Old Dec 4, 2006 | 04:26 AM
lethal93ta's Avatar
look at the pic, it has a mount on the filter that I made its bolted to the bar that runs across the body, Im only running 12 an to the pump then it will be 1/2 in alu after that. I know the right rear would be better but theres no room over there and i have a spohn drag race rear sway bar I dont see my car leaving the line that its putting all the fuel over there it should leave straight if not I can adjust that with the end links, and I never run any less than a 1/2 tank.
Old Dec 4, 2006 | 07:27 AM
mdacton's Avatar
well just do like you said and put it where the stock filter was.....I have that spohn bar too if you haven't run the car with it yet you will like it my car was pulling the left almost 2ft and the rt. 6 inches now its perfectly strt.
if you run 1/2 tank i think you will be fine
Old Dec 11, 2006 | 08:25 PM
lethal93ta's Avatar
I got it mounted tonight, it hangs a little lower than I wanted it to but it should be fine, its still higher than my exhust and I never hit that + I have a taller tire than I use to in the rear.
Old Dec 12, 2006 | 05:31 PM
mdacton's Avatar
looks good...lots of $$in AN
hey shoot me a pm I got a ? on the DFI
Old Jan 2, 2007 | 05:43 PM
FASTFATBOY's Avatar
http://web.camaross.com/forums/showthread.php?t=350659
That line above the muffler is a bad idea, in traffic the heat from the muffler will rise, could possibly boil the fuel in that line, bad idea.
David
Old Jan 2, 2007 | 10:06 PM
A 1/2" fitting is the equivalent of -8AN..... sounds too small for the suction line on a pump that large, even if you attached a -12AN line to it. If the fitting it too small, the heat from the exhaust pipe will make the situation even worse, possibly vaporizing the fuel in the suction line because of inadequate net positive suction head. Because of its high vapor pressure, gasoline will flash very easilly with too much pressure loss on the suction side of the pump. Hopefully the fitting on the tank is also one of the "radiused" fittings specifically designed for pump inlet, and not a sharp edged fitting that hurts flow.
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 3, 2015 07:59 PM
squarehead
Nov 21, 2014 08:02 PM
racer08
Jul 23, 2002 05:43 PM
