Mallory 685
Old Nov 18, 2006 | 09:19 AM
94_camm's Avatar
Mallory 685
Any have a diagram or anything on how to hook up the mallory685 to a 94z?
Old Nov 19, 2006 | 11:44 AM
2000GTP's Avatar
In order to avoid cutting and splicing your factory wiring, I would purchase the MSD wire harness as well for thirty bucks. Then this is how the wires coordinate:
MSD harness to Mallory 685
Red to Red
Black to Black
White to Green
Orange to Yellow
Other then that, you are just hooking up two other wires, one for the power and the other for ground. If you have a nitrous kit, you will take it a bit further as you also have wires for the timing retard and the window switch.
Old Dec 3, 2006 | 05:36 PM
94_camm's Avatar
i still dont get it...which red wire.which green wire thier like 2 or 3 of each color...
Old Dec 3, 2006 | 06:26 PM
2000GTP's Avatar
Here is a link to the instructions: http://www.centuryperformance.com/ma...78_Hyfire6.pdf
Hopefully that will help you better.
Old Dec 16, 2006 | 09:35 AM
94_camm's Avatar
ok so i got those other wires..now i need to get a map sensor 3 pin connector?were can i get one of those? then for the other green/black wire it says magnetic pick-up whats that mean?and then the last 3 wires...yellow/violet/orange...when it says 12 volt activates does the mean to the battery? then were do i put the rpm switch output to??
Sorry bout the questions not a big electrical guy!
Old Dec 16, 2006 | 09:49 AM
2000GTP's Avatar
The MAP sensor connection is not needed and neither is the magnetic pickup. There will be alot of unused wires on this box. As for the other three wires you mention, the orange wire I didn't use at all. The violet wire is for your window switch and will provide a ground. You will need to connect this to the main ground of your nitrous relay. The yellow wire needs 12 volt activation source. It does NOT mean it needs a permenent source from the battery. What you do is connect it to the 12V activation side of the nitrous relay, which can be done with a wire tap. When the nitrous system is activated, the nitrous relay will send 12V to both the nitrous/fuel solenoids and also to this wire which will initiate the timing retard. This is why you don't want to connect it directly to the battery because then the timing retard will be active all the time, something you don't want. Did you at least get the main power and ground hooked up and the four wires for the ignition coil? If you have done that, then the car should be capable of starting. I hope all this makes sense and is clear to you.
Old Dec 16, 2006 | 10:01 AM
94_camm's Avatar
yes all of those other wires are hooked up jsut needed to know were the other wires needed to go!!thanks for the help
n2oblkz
Oct 22, 2015 02:31 PM
blksunshine
Aug 9, 2003 10:55 AM
justahoe
N2O Tech
Apr 11, 2003 09:26 PM
vendela99
Mar 8, 2003 01:59 PM
vendela99
N2O Tech
Mar 5, 2003 06:57 PM
