Friendly Reminder (avoid problems)!!
Old Nov 14, 2006 | 02:57 AM
disco192's Avatar
Just an FYI for you LT1 T56 guys. When you install a tranny and remove the bolt that holds down the clutch fork.... PUT LOCKTITE ON THAT BOLT!!!!!
Just a reminder. I had that bolt back out on me and made my car inoperable. When I pressed in the clutch, the fork rubbed the pressure plate and eventually stalled out the motor. (This happened in neutral and coasting. I pressed in the clutch and the motor died)
So I pulled the tranny, tightened the bolt (and added locktite), and re-installed it. Everything is running fine now.
Just wanted to give everyone a heads up.
StansZ28
Feb 19, 2015 07:39 AM
CARiD
Feb 9, 2015 09:35 AM
edxiel
Jan 24, 2015 07:40 PM
BMP Mike
Jan 7, 2015 11:12 AM
Dec 5, 2014 11:42 AM
