Foose Nitrous wheels
Old Nov 13, 2006 | 04:04 PM
Chevy3Girl's Avatar
I was just wondering if anybody knew if they made these wheels that would fit a 92 Camaro RS? I looked on eBay and they have some 15s but the guy said I would need a 4.75 bolt pattern and all he had was 4.5. Just wondering if anybody knew anymore about them, cuz I have no clue, I'm learning. thanks for any help and sorry if it's a stupid question.
Katy
http://cgi.ebay.com/ebaymotors/4-15-...spagenameZWDVW
Old Nov 20, 2006 | 03:05 PM
Billsblue89's Avatar
Katy,
The skies the limit with regards to putting wheels on your 92. You can put 15", 16" 17" heck even 18" will fit and look good.
The correct bolt pattern for your car is 4.75" and no 4.5" will NOT fit. They myut be 4.75" or 120.65mm (metric size).
Whether or not the wheel will fit depends on the backspacing. This is the amount of rim that will fit inside the wheel well. Most people on a 7" rim will put a 3-4" backspacing on the wheel. For a 8" rim again most prefer a 4" bs. Also you must take care that any tire you put on even larger ones have close to the same height as the original or the speedo will be off. They can be wider but should should be much taller. There is literally hunderds of ideas on this. As good place to start is www.thirdgen.org. This site is dedicated to third gen camaros like yours and the people are top rate and can hlep with ANY question you have. If you want you can email me at billcarter@sympatico.ca and I can send you some specs on what tire/wheel/backspace sizes will work.
Enjoy
Bill Carter
Mississauga, Canada
Old Nov 20, 2006 | 05:13 PM
Originally Posted by Billsblue89
Katy.........
They can be wider but should should NOT be much taller. There is literally hunderds of ideas on this...........
I think that's what you meant to type.
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
bandit383lt4
Dec 21, 2014 09:12 PM
