Winter Good Time To Start Zaino?
Old Nov 16, 2002 | 02:45 PM
bAZ's Avatar
bAZ
Question Winter Good Time To Start Zaino?
I have been putting off starting to use Zaino for quite awhile, and as winter is starting to come here I am mainly worried about the damage the salt and other chemicals we use on our roads are going to do to my Mystic Teal paint on my Camaro. So I do have a few questions especially as it is rather cold now (below 10 degrees celcius):
Will the cure time or amount of products I use change than the recommended because of the cold?
Will snow/freezing rain still bead up? How should I remove it?
How should I remove road salt and other dirt that gives your cars that wonderful white color without scratching the paint?
Should I protect the T-Top/window seals with anything before the extreme cold? (sometimes up to -30)
Will Zaino's protection be able to stand the extreme weather?
Is there any other prep steps I should take before starting in the cold? instead of the normal dawn wash/z7 car wash then claybar to zaino products.
If there are any other tips or advice you guys have for a newbie Zaino user please let me know, especially anything to make it easier in the cold
Appreciate your time and responses,
Thanks alot.
Old Nov 16, 2002 | 06:00 PM
KevinSS's Avatar
Re: Winter Good Time To Start Zaino?
No, with ZFX activation, this is not a problem.
You don't, if you have something frozen on the surface of the car, do not try to remove it until is melts, trying to do so would be like rubbing a rock over the surface, scratching will result.
Hand wash the car with a car soap and cotton wash mit, keep the mit fresh and washed out many times during washing and before laying hands on the car do a lot of pre rinsing.
Some people use Dielectric Grease, but there are many products you can buy that are good for seals, our Z-16 Tire Gloss is great for that.
Yes, cold and heat have no effect on the synthetic properties of Zaino.
Not really.
rideordie
Nov 5, 2019 04:52 PM
Queens94z28
Dec 20, 2014 09:11 PM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
Dec 1, 2014 08:08 AM
