wheel need re-balancing or alignment
Old Oct 30, 2006 | 09:38 AM
Unertl42's Avatar
I just got new g-forces mounted on the front wheels, and so last night I decidedto test them out. Well around 120-130 the car was shaking and so I decided that I had to slow down. It was definitly from the front end, so I was wondering if I just got a crappy balancing job, which by the way cost me $70 and took the morons over 3 hours, or maybe its alignment?
Old Oct 30, 2006 | 07:58 PM
Z/28Camaro4life's Avatar
Was the car vibrating at 65 or it just happend at 120-130??? It is not a wheel alignment it is most likey a blanance or a bent rim. Hope this helps you out. Was it vibrating when you were braking b/c then its probably warped rotors
Remember-
pull/wheel off center = alignment
vibration= balance/bent rim
Old Oct 30, 2006 | 08:25 PM
Unertl42's Avatar
thanks, I'll go get it rebalanced
Old Oct 30, 2006 | 08:31 PM
landstuhltaylor's Avatar
that seems extremly expensive and a long time to get them balanced. see if they can cut you a deal.
Old Oct 30, 2006 | 09:15 PM
Zack's Avatar
hell yea it is..****ing ripped!
2QUIK6
Jul 15, 2015 07:46 PM
jasonduaine
Jun 4, 2015 09:29 AM
achipfef
May 5, 2015 10:20 AM
Hurin
Dec 13, 2014 07:38 PM
