Sway bar bushings
Old Oct 27, 2006 | 01:02 PM
JohnD's Avatar
Sway bar bushings
On a '97Z, are the sway bar end pieces the same front and rear? It looks like 10221779 is the same part # for both. I found a 32 mm front sway bar cheap on ebay and I was thinking of replacing the swaybar grommets front and rear at the same time when I changed it out.
Old Oct 27, 2006 | 01:43 PM
SevenStars's Avatar
No they arnt the same, the front it 30mm and the rear is a 21mm I think.
I have a extra set of new 32mm poly bushings for what its worth.
Old Oct 27, 2006 | 01:44 PM
JohnD's Avatar
I knew the bushings were different. The question was are the grommets on the end links the same. They look like they are.
Old Oct 27, 2006 | 01:53 PM
Bud M's Avatar
You are referring to the endlink bushings? They are the same.
Old Oct 27, 2006 | 07:14 PM
shoebox's Avatar
IIRC, the complete end links are the same front and back.
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
force10
Jul 30, 2015 04:56 PM
SpeedJunkee
Jul 19, 2015 09:06 PM
