Torque arm?
Old Oct 25, 2006 | 10:39 PM
camarookid's Avatar
Torque arm?
Please explain the function of a TA and the advantage of an after market unit Thank You!
Old Oct 25, 2006 | 11:50 PM
Dave '97 Z28 M6's Avatar
The torque arm (TA) keeps the axle from "wrapping", where the front of the axle tends to pivot up and the rear pivot down under hard acceleration. The factory piece in F-bodies is stamped steel, and the front mounts to the transmission tailshaft.
Tubular aftermarket TA's are stronger and stiffer than the factory stamped steel unit, thus are less prone to flexing and breaking. Some aftermarket TA's relocate the front mount from the transmission tail shaft to the floorpan of the car, reducing the stress on the transmission and tranny mounts. Many aftermarket TA's are adjustable, allowing the pinion angle to be changed to improve the car's setup for racing.
Old Oct 26, 2006 | 12:30 AM
obaja's Avatar
Thumbs up
Wow very well explained. thank u
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
autoxr166
Sep 25, 2015 04:21 PM
Jake Bialke
Sep 24, 2015 11:31 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Bxlt1
Sep 17, 2015 08:31 AM
