New best 60' at least with rollbar!
Old Oct 22, 2006 | 02:24 PM
T/A lt1's Avatar
Well I finally decided to put a 6 point rollbar in my car after getting told I couldn't run that fast with no bar a couple too many times. I went out with a new pair of 325/50/15 ET street radials and ran into a couple problems, one being one of my stock fans quit, burnt the fuse, so the car got to 200+degrees. So while fixing that problem and cooling the car down I must have wet the da*mn optispark so the car was acting up. Finally I got it running decent and sprayed it to a 1.41 60' on Drag radials! Still with the stock torquearm, panhard rod, rear shocks and all. Well it lifted both front tires and when I shifted to second it started cutting out so I let off for a second then got back in it and it missed a little but still ran 130mph out the back. Here is what the slip looked like:
60'_1.41
1/8_ 6.65@103.2mph
1/4_10.33@130mph
It wasn't the best run but I plan on pulling the distributor and may go with a coil per cylinder setup but haven't decided yet. Later Clint
Old Oct 22, 2006 | 03:52 PM
96flame's Avatar
Re: New best 60' at least with rollbar!
Enjoyed reading the article in GMTHP about your car. Its amazing what you 've done with stock suspension and torque arm. Looks like you made the best of a bad day in the end.
Old Oct 22, 2006 | 04:26 PM
marshall93z's Avatar
Nice! Which issue was your car in?
Old Oct 22, 2006 | 05:19 PM
96flame's Avatar
It was August 06. Oh yeah your original intake works good BTW.
Old Oct 25, 2006 | 08:24 AM
T/A lt1's Avatar
Thanks guys, I am swapping this opti out and going to try both stages of n20 on the next outing. Later Clint
Old Oct 27, 2006 | 06:11 PM
Jameslt1TA's Avatar
Ill bet that felt pretty darn cool. Let me know what it does with the second stage man.
Old Oct 28, 2006 | 02:24 PM
Cmr0z28's Avatar
Badass!
Old Oct 28, 2006 | 06:08 PM
twocamaros's Avatar
wat kind of hp is this car puttin down?
Old Oct 30, 2006 | 08:22 AM
T/A lt1's Avatar
My car only put down 375rwhp N/A and 510rwhp on 200NX but the converter was on it's way out and has since been rebuilt and tightened up. It is no dyno queen buit always runs pretty quick. Thanks for the compliments guys. Later
Old Oct 31, 2006 | 06:22 PM
twocamaros's Avatar
u gave me allot of hope for my car.. damn.. i have similar numbers an similar setup if i have hit 9s i prolly blow a load.
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
Carpe Diem
Aug 20, 2005 12:33 PM
talos
Pacific
15
Feb 5, 2004 05:47 AM
Ken S
Apr 25, 2003 10:54 PM
D James
Sep 9, 2002 08:09 AM
