94 camaro heater question
Old Oct 14, 2006 | 04:35 PM
Moshbmx1's Avatar
I have a 94z28 the problem is that it does not blow very much heat or hot air. If i change the temp from the red to even the middle it will blow more and if I put it all the way in the blue for air it will blow COLD air great! The hose out of the thermostat housing is hot, and both into the heater core and out are comparable-both hot. I can let it sit for 20 minutes running or driving-it makes no difference. Please help guys. Thanks.
Old Oct 14, 2006 | 06:18 PM
shoebox's Avatar
Re: 94 camaro heater question
I know you say both your heater hoses are hot, but a clogged heater core is the most common cause of no heat. Try flushing the core. What could it hurt?
Old Oct 14, 2006 | 08:35 PM
MyShibbyZ28's Avatar
Flushed my core and heat came back... now its been a while and it needs it again...
Britbilly
Jan 7, 2015 08:49 PM
CaRParts102
Dec 6, 2014 08:45 AM
pologreen97z
Dec 2, 2014 10:42 AM
Black93lt1
Nov 21, 2014 07:30 PM
